starting issues
Old Aug 27, 2008 | 02:04 AM
The MPI 'Bird's Avatar
Car: 1982 Trans-am
Engine: 305 CFI
Transmission: Rebuilt Th-350
Axle/Gears: 3.23 posi
starting issues
So it's like this. I recently did an almost full tune up on my car (plug wires, spark plugs, cap/rotor, ignition coil, oil, belt, pcv valve, O2 sensor, and seafoamed the car) thinking that would solve my starting problems, but it did'nt. whenever I go to start my car, on days were it sat for a long time (over nite) it would start up in a split second, like almost as soon as i turn the key, but sometimes, it will take a solid 5-6 secs of cranking before it will just barely catch and startup. normally when it just cachtes i have to give it some gas so that it does'nt die on me, and everytime it start it runs super rich like you can really smell it. my question is, whats up with my car? its throwing absolutely no codes, and the only i have left to do is fuel filter, so I don't know what it could be. do you think resetting the timing will solve my problems?
any help would be great!
Old Aug 27, 2008 | 10:51 AM
pairtoe's Avatar
Re: starting issues
did you check the battery?
Old Aug 27, 2008 | 06:08 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: starting issues
Is your timing set right?
Old Aug 29, 2008 | 08:14 PM
Car: 1982 Trans-am
Engine: 305 CFI
Re: starting issues
Battery is good, bought it two months ago. Could that be timing? like i've never done timing before and I have no clue what the timing should be at. Is that something I should look into?
Old Sep 2, 2008 | 12:03 PM
zerofailure's Avatar
Car: 89 Firebird
Engine: 2.8L
Re: starting issues
i dont see how it could be ure timing... it runs normal after start right?...
my guess would be fuel pressure regulator...
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
