Need some Help on Starting issue
Old Aug 27, 2008 | 05:12 PM
paul84z's Avatar
Car: 1984 z28--1987 LT
Engine: 305HO
Transmission: turbo350
Here goes...... 1987 2.8
Freshened up entire engine, new gaskets, hot tanked almost every part
new timing chain, 4 degrees advanced.
after re-assembly car will not start without a shot of ether\ starting fluid.after she is running she purrs like a kitten
here's what i know
45 pounds of pressure at the fuel rail
hooked ecm up to the snap-on solus computer, ecm getting all the readings it needs, cool temp, maf, tps and so on
timing is set at 10 degrees btdc--dead nuts on
no vacuum leaks
no leaks of any kind
at this point i am at a loss. i would appreciate any help or suggestions you guys have
thanks paul
Old Aug 27, 2008 | 06:01 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Need some Help on Starting issue
Are you supposed to advance the cam? I think that that would be your problem. I could be wrong though.
Old Aug 27, 2008 | 06:32 PM
paul84z's Avatar
Engine: 305HO
sorry poor explanation, this paticular timing set allows for a 4 degree advance or retard on the cam sprocket
Old Aug 27, 2008 | 07:44 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Old cam or new one? Stock cam? IIRC some cams already have the advance built in so you don't have to degree the gears.
Old Aug 27, 2008 | 08:42 PM
jimri's Avatar
Car: 2001 Malibu
Fuel system Cold start hooked up ?
Old Aug 28, 2008 | 08:21 PM
paul84z's Avatar
Engine: 305HO
cold start hooked up and leak free. any idea what a good cold start injector should ohm out to?
used the original stock cam. it measured out to be well within spec
Old Aug 28, 2008 | 09:44 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Your cold start shouldn't be your problem. I disconnected mine and the car fires right up every time. It just makes startup a little quicker, the 3.1s didn't have them.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
