Fuel pump relay on an 87 2.8?
Car: 1984 z28--1987 LT
Engine: 305HO
Transmission: turbo350
hey fella's,
where is the fuel pump relay on a 87 2.8?
should i hear the fuel pump evry time i cycle the key, or does it only energize if it losses its prime?
thanks in advance
paul
thanks in advance
paul
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Fuel pump relay on an 87 2.8?
should be on the firewall on the driver side...beside the brake booster. Should cycle a 2 second prime, unless the car wasn't shut off, then it may have to wait 10-15 second before it tries to prime again.
