Experience with Accel Injectors
Old Sep 9, 2008 | 06:02 PM
Blaze of Glory's Avatar
Car: 92 Firebird
Engine: 3.1L V6
I am looking into replacing my fuel injectors. I've read the ditch your stock injectors thread and I'm not convinced the ford injectors are the way to go. I'm not trying to turn my car into a hot rod, I just want something that will give me trouble free operation.
I'm looking at the 15lb Accel 150615. I've looked and I haven't found too much information about them.
Anyone that has used these particular fuel injectors please share your experience, good or bad.
FYI, the main reason I'm don't want to try the ford injectors is that I read they can make your car run a little rich. Is this the case? Currently my idle is already a little rich, so I want to avoid anything that would make it worse.
Old Sep 10, 2008 | 12:07 PM
jrsrnr3's Avatar
Re: Experience with Accel Injectors
my camaro came with those same injectors and always leaked and ran really rich and was hard to start and idled like crap. I replaced them with the ford injector from five o motorsport with the replacement injector, and now the car has really good low and mid range power, idles real smooth. i'm really happy with the up grade.
Old Sep 10, 2008 | 02:27 PM
Car: 92 Firebird
Engine: 3.1L V6
Also realize that I am in California. Passing smog is something else I am concerned with.
Has anyone had any issues with passing smog with the Ford or Accel injectors?
Old Sep 11, 2008 | 12:25 PM
jrsrnr3's Avatar
I also live in california and after installing the injectors I had the camaro smogged at my local station and the car actually pass without any problems and i'm a really happy person.
Old Sep 11, 2008 | 12:32 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Aslong as your not changing injector size, it shold pass cali emissions. Ford or accel.
Actually, if its a stock ford product, then it is forsure cali epa approved
Old Sep 11, 2008 | 01:39 PM
jrsrnr3's Avatar
that is what i put in the camaro was a set of taurus/t-bird/ranger injector, i cant remember if it was the 15 or 17# injector. all i know is that when i took the car to smog it passed with flying colors and the smog shop didnt even know i had ford injectors in it. i have a copy of the smog test but i cant figure out how to post it on the forum. i have the photobucket but i forgot how to use it. The part# F47e,F87e brand new $239.28 shipped to my house. The injector fit right in with out changing the o-rings.
Old Sep 11, 2008 | 02:29 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
actualy the stuff for cali has to be CARB approved..
Old Sep 17, 2008 | 12:52 PM
Car: 92 Firebird
Engine: 3.1L V6
So I started looking into the Ford injectors and found something out.
I was looking up injectors for a 98 V6 Mustang and I noticed the Accel injectors they sell for the Mustang are the exact same ones they sell for our cars.
Then I remembered hearing that you need to use a thicker O-ring with the Ford injectors to prevent leaking. I also heard that the Accels leak right off the bat. I wonder if there is a connection here.
Old Sep 17, 2008 | 03:03 PM
Dale's Avatar
Engine: 350 S-TPI
Just remembered something here since this is back up.
Ford has 2 different style injectors. Needle or disc. Make sure you get the disc.
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
