Lower Intake Swap Question?
Old Jan 1, 2009 | 05:51 PM
RS90CAMARO's Avatar
I just bought a 1990 camaro with a 3.1l I was told the waterpump went out but when I started tearing down the motor I found that the heater hose connector was broke and it looked like someone had tried to JB weld it back in and gumed up the hole. If I'm not able to tap the hole and install a new connector I need to know what lower intakes will fit on this engine. The wrecking yard near me doesent have any 3.1 camaros so what other cars or trucks had this engine? Would a 2.8L manifold work? Would one from a transverse engine work?
Old Jan 1, 2009 | 06:17 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
Re: Lower Intake Swap Question?
the intake from the 2.8 is the same. and if im not mistaken the 3.4 intake from camaros and firbirds were the same as well
Old Jan 1, 2009 | 06:18 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The 3.1 was GM's base model V6. It was an either base package or option for a good percentage of their passenger cars in the early 90's (Cavalier, Corsica, Lumina, Celebrity, and I think Beretta). Pontiac's had them in the same body style cars (Sunbird, Grand Prix, and 6000).
Old Jan 1, 2009 | 06:59 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
thats a very good question actually. would a FWD intake work on our engines?
Old Jan 1, 2009 | 08:21 PM
project89's Avatar
only if it has iron heads.
unfortunatly though the 2.8/3.1 manifolds are the same.there is a lil bit of work needed to make a 2.8 mani fit ona 3.1 or vise versa.
2.8 manifold has a cold start injector,were the 3.1 dosent
the difference is on the 3.1 instead of a injector it has a plug in the manifold. u may be able to remove the injector and install a freeze plug in its place. but im not sure if it is infact a freeze plug or a nother special plug
Old Jan 1, 2009 | 08:40 PM
RS90CAMARO's Avatar
Where is the cold start injector located on the manifold? Is that all that needs to be done?
Old Jan 1, 2009 | 09:04 PM
project89's Avatar
its on the back of the manifold near the firewall, u cant miss it, and yup thats the only thing u need to do to put a 2.8 manifold on a 3.1
Old Jan 1, 2009 | 09:07 PM
RS90CAMARO's Avatar
Is it on the lower, middle, or upper manifold? Does anyone sell a delete kit for the injector?
Old Jan 1, 2009 | 09:28 PM
lower, from the fuel rail. you can just leave the injector in and leave it as is.
Old Jan 1, 2009 | 11:11 PM
RS90CAMARO's Avatar
OK one more question is the 2.8 manifold taped the same size as the 3.1 under the thermostat so I can screw in a new heater hose connector if I have to replace it?
Old Jan 1, 2009 | 11:28 PM
I'm 99% sure they're the same size, but they'll also be a real bitch to get the old ones out. just to warn you.
Old Jan 2, 2009 | 06:45 PM
RS90CAMARO's Avatar
Thanks for the help everyone, today me and my dad were able to chisel the rest or the jb weld out of the hole and retap it so we could put a new fitting in. I coated the fiting with grey permatex just in case so if I'm luckly it wont leak. If anyone needs to know the thread size is 1/2"x14 NPT. I got a tap set from harbor freight for 14 dollars and the fitting from kragen for about 9 dollars. Also the water pump was bad it was frozen solid so I got a new one and hopefully tomorrow if it doesnt rain I will get this thing started.
http://www.harborfreight.com/cpi/cta...emnumber=91395
http://shop.oreillyauto.com/ProductD...pe=938&PTSet=A
Old Jan 4, 2009 | 02:47 PM
project89's Avatar
i just happened to fin a picture i had from when i riped my old 2.8 down.
i see u got it fixed but ill post it so anyone else wondering the same thing can see the difference
in this pic u can see the coldstart injector inthe back of the 2.8 manifold
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
