speed sensor
Old Mar 5, 2009 | 10:16 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
speed sensor
soo.. how much trouble are they to change.. since mine is throwing a vss code. now im getting a failed egr code also.
Old Mar 6, 2009 | 06:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: speed sensor
'89 Firebird, that one is probably at the transmission. If so it is rather easy to change. Jack up drivers side, put jackstands under frame rails, unplug connector (two wire), remove single bolt. Slide VSS out careful not to drop the gear off the end. Move gear to new VSS and reverse.
The VSS will be located on the tail shaft housing, drivers side. Right below the shifter.
RBob.
Eric2ndGen
Nov 5, 2015 01:51 PM
angel2794
Sep 8, 2015 06:22 PM
IROCtometal
Sep 2, 2015 02:01 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
