<help>
Old Mar 10, 2009 | 09:48 PM
davidopliger's Avatar
Car: 1991 Camaro RS
Engine: :( 3.1
<help>
1991 rs 3.1....
distributor is less than a year old.. a checked the coil, ignition control module, and ohms tested the pickup coil.. all are good.. coil is pushing out 12 volts to the distributor... which has a brand new cap... (just in case) less than a year old computer.. 3 month old plugs... 2 month old fuel pump( that works.. just tested today)... all the above iteams work... but NO SPARK!!!!!! ( added new parts in less than the past 2 years....new and or checked tps, maps, iac, wires, rotor button, distirbutor, timing chain, ignition switch( which was a pain in the a**) fuel pump (the biggest pain in the a**).... thanks...
car ran the other day and wouldn't start after shutting off... i assumed the coil was at fault so i bought a street fire coil( product of msd) and it ran.. so i figured that was the problem... cranked about 10 times.. then as i was leaving a parking lot it just shut off.. so i tested the coil.. it was good so i replaced it anyways with another one... (as defected at advance ) just to be sure... still no crank.. twice it has fired about 4-8 times on the cylinders and died.. never actually cranked.. but no FIRE WHAT SO EVER. and everything seems to be good and everything was tested... HELP HELP HELP HELP.. anything i might have missed???????????????????????????????????
