1986 Firebird Fan Switch
Old Mar 18, 2009 | 04:47 PM
RandyTyler's Avatar
Car: 1986 Firebird
My son has a 1986 Firebird 2.8l Multiport Fuel Injection motor. We are trying to find the fan switch location. Fan keeps running, replaced fan relay but can not find fan switch! Help....please
Old Mar 18, 2009 | 05:38 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 1986 Firebird Fan Switch
The fan switch is in the pass side head, in between the head and the lifting eye. However, if the car has air conditioning, there is a possibility that one of the pressure switches isn't working, most likely the one in the line running down the passenger's side frame rail near the air cleaner. If you disconnect either with the key on and the fan turns off, it's bad (shorted fan switch or open pressure switch).
Old Mar 18, 2009 | 06:59 PM
RandyTyler's Avatar
Car: 1986 Firebird
Found fan switch back of head on passenger side and also found connection on air conditioning line. Disconnected wire and turned key on, fan still runs. Does that mean fan switch is bad....
Old Mar 19, 2009 | 07:53 PM
Engine: 2.7L V6
Axle/Gears: 4.41
If you disconnected the A/C switch, yes the fan will run. The switch normally connects the 2 terminals together (closed when 'off') until it is switched by the pressure in the line.
If you leave the A/C switch connected, pull the fan switch connector off, and the fan shuts down, the fan switch is grounded and is bad. If you use a piece of wire to connect the 2 terminals of the A/C switch and the fan shuts down with both it and the fan switch disconnected, the A/C switch is bad.
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Aug 16, 2015 12:21 PM
