Help! Intermitant stalling narrowed down to Distributor... I think.
Old Apr 20, 2009 | 09:25 PM
BiggRedd's Avatar
Car: 1986 Firebird
Engine: 2.8L
Transmission: 5Spd
I bought an 86 bird with a 2.8 that ran well for a few months...
Then:
Changed starter, replaced posi cable.(found out later it was run the wrong way by previous owner) oil change at Wal-Mart, posi cable fell burned onto header meled down battery happened within 500yds of W-M. New Battery secured new posi. Shortly after car would shut down randomly. I would drive for awhile sop at a store, come back out and car would start then immediatly stall. After about 10 min or so it would star up and be fine for anywhere between a day to a week. After reading many threads, I replaced my coil (was wire-tied to the firewall). The original was still on the bracket so I removed it and drilled the rivits and put in new coil. I broke and replaced the egr vacuum solenoid. I also changed my plugs guy at Advance sugested titanium tt's. Thats when I noticed my distributor would turn slightly. Two days later driving home car stalled and woulded start. Under the hood I noticed the distributor had moved slightly. I can turn it by hand about 45* eaither way (probably restricted only by wires in the way). If I turn the distributer alittle then back my car will start again and run for awhile. if I punch it though it will stall and I have to turn the disty again to restart it. I retarded the timing abit and it seamed to last longer before I had to repeat the process.
I cannot find the hold down clamp or bolt or even where they should be. I think the PO left them off, he seemed to take a lot of shortcuts I've been fixing as I can. I can't find any pic's or good descriptions.
Old Apr 20, 2009 | 10:01 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
Re: Help! Intermitant stalling narrowed down to Distributor... I think.
Then:
the cars out of time. get a hold down for it and put it in time. service engine soon light on? engine light on?
Old Apr 21, 2009 | 01:02 AM
BiggRedd's Avatar
Car: 1986 Firebird
Engine: 2.8L
Transmission: 5Spd
I/m calling the dealership in the morning to try and get a hold down. engine light is not on and there are no stored codes.
Old Apr 23, 2009 | 07:45 PM
BiggRedd's Avatar
Car: 1986 Firebird
Engine: 2.8L
Transmission: 5Spd
Finally got a hold down. Adjusted timing and she's running great. Thanks.
Old Apr 23, 2009 | 08:08 PM
sloick's Avatar
Car: Many
Engine: Several
Good to hear. help it stays running great.
Pac J
May 17, 2020 10:44 AM
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
