Advice: Cracked Heads
Old May 5, 2009 | 12:23 PM
milleym's Avatar
Car: 1986 Firebird S/E
Engine: 2.8L 173cid V6 MFI
My engine has 175k miles on it. When I bought it (for $900) I didn't even make it home before she died on me; the mechanic told me it was a blown head gasket.
I took the engine apart, and today, I brought the heads over to a achine shop to be cleaned, tested, and resurfaced if needed; the mechanic just called me and told me that I need new heads because they are both cracked.
Rock auto has heads for around $275 per head. Should I invest the $600 into new heads, or would I be better off completely swapping the engine?
Is there a better place to buy the heads? If I were to get a crate engine, who should I buy it from?
Thanks,
-Mark
Old May 5, 2009 | 07:08 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: Advice: Cracked Heads
ebay or junk yard. You can get a set for $100.
Old May 5, 2009 | 07:20 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
I have a set of 3.1 heads that are stripped down...I took off the the valves, springs, seals, and tried to give them a good clean. I was planning on rebuilding them completely...but plans changed a little form then. If you want to pay for shipping they are yours.
The only thing is that all the parts got mixed up....got to love it when your brother has a dog that loves to cause havoc. You could just transfer all the parts from your heads over. ill go give them a check and post up pics if you want.
Old May 5, 2009 | 08:31 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
If youve got the money, swap a 3.4 in. If not, get a set of 2.8/3.1/3.4 heads from a junkyard and put them on. Theyre all the same from 85-93.
Old May 5, 2009 | 09:38 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
getting heads from grimmics sounds like a good idea to me.
Old May 5, 2009 | 10:49 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Sounds like the perfect excuse to do a 3X00 swap!
Frozer!!!
Jan 19, 2024 04:55 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
theshackle
Mar 5, 2017 06:37 PM
michealleger
Aug 26, 2015 03:29 PM
