Possible Fuel pump regulator
Old Jun 16, 2009 | 12:35 AM
Irocz207's Avatar
Car: 90 Camaro RS
Engine: 3.1
I have a 3.1 it has been sitting for several years i replaced fuel pump. fuel filter spark plugs and wires. when you first start it up the car runs fine but wen it warms up the car has no power and jus misses i heard from someone it may be a Fpr any possible ideas. oh and by the way the service engine light go off every now and then but mostly stays on.
Old Jun 16, 2009 | 07:58 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: Possible Fuel pump regulator
need to check the codes first before continuing any farther.
Old Jun 16, 2009 | 10:00 PM
Irocz207's Avatar
Car: 90 Camaro RS
Engine: 3.1
how do u decifer the codes
Old Jun 16, 2009 | 11:05 PM
Irocz207's Avatar
Car: 90 Camaro RS
Engine: 3.1
it is throwing a code 43
Old Jun 18, 2009 | 06:46 PM
Poptart's Avatar
Car: '91 Firebird
Engine: V6
I'm having the exact same problem with mine. I haven't had time to go through the fuel system and clean everything out but I'll give you the same advice others told me.
One suggestion was rust in the gas tank. Since you replaced the fuel pump id assume you didn't notice alot of rust deposits in the tank. Or rust clogging the fuel filter or fuel injectors.
Another suggestion was a bad FPR.
And finally someone also said it might be a vacuum leak.
I'd put my money on the FPR since it seems to be the only remaining suspect.
Old Jun 22, 2009 | 07:46 PM
entrig00's Avatar
Car: 91 Camaro RS
Engine: 3.1 V6
Transmission: t-5
so was it the fpr?
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
