MPFI to carb questions
Old Jul 6, 2009 | 12:08 PM
charlie 1's Avatar
I want to take off the mpfi off my engine and put a reg. carb and manifold, could anybody assist me in what year intake to get it off of what engine. I am putting 3.1 heads on a 2.8 block. I dont like mpfi for bracket racing, that why I want carb.
Old Jul 6, 2009 | 02:33 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
Re: MPFI to carb questions
find an older 2.8 car and pull the intake. or maybe the 2.8 s10 intake is the same?
Old Jul 6, 2009 | 07:50 PM
keith_AE2010's Avatar
Car: 98 Camaro, 89 Camaro RS
Engine: 3.8l & 2.8l V6
Transmission: 4l60e & T5
Axle/Gears: Open 3.08 & lsd 3.42
Is it just that easy? Swapping intakes?
Old Jul 8, 2009 | 10:19 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
It is that easy, also depending on what 3.1 (iron) heads youre referring to, theyre identical to the 2.8 (iron) heads.
Old Jul 8, 2009 | 02:47 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
ya its that easy. and yes the s-10 had the same motor in certain years. i think its just simple stuff to change like maybe the fuel sending unit.(maybe)
I don't know about the 3.1 heads, but just do a search on it.. maybe that will help. people swap them all the time.
Old Jul 8, 2009 | 04:57 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
search craigslist in your area under all sort of keywords to find parts cheap.
Like jimmy, s10, s15..................
they put them carbed ones in the "trucks" longer and allot more.
I still have that option on my plate but I am not chainging the base bottom intake. What ever I do, if I go carb Im not changing it.
blower deal kept falling through, last thing to end it was everyone sayin ya can't use an air only blower with a carb like he did. Though his adapter would of made going carb lots easier when keeping the stock MPFI lower intake in place. Im not changing it.
answer: rubber expanding freeze plug type repair do-dads to pluf injector holes. They can hold back hot coolant, and the intake sucking with just pull em in tighter as they are tapered. A blow out would be rare and from only a severe backfire that will make ya not care about the $2 plug coming out.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
