still over heating
Old Jul 13, 2009 | 01:06 PM
confucius101's Avatar
still over heating
Ok so for the last two weekend i've been trying to get my fan working right
as it sits now the fan will spins freely by hand but nothing other wise
I swapped out the fusible link off to the pass side of the fan
this gave me power to the back relay on the driver's side
but i'm still not getting any power to the temp sensor under the throttle body
I would love to get this working properly
what am i missing or what should i try next?????
Old Jul 13, 2009 | 01:51 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Re: still over heating
Have you ran a direct test line to the battery to make sure the motor isn't bad. I swapped mines out about a month ago same issues.
Old Jul 13, 2009 | 02:16 PM
No for whatever reason i haven't done that yet
but if it was the fan motor........
then wouldn't i have power @ the plug going into the temp sensor??????
Old Jul 13, 2009 | 03:21 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
Technically you should, just an idea I threw out there b/c that was my issue. I had replaced the fuse on the firwall to the a/c control but that wasn't my issue. So I ran a direct hot wire to the fan and still nothing. Replaced the motor and been good ever since.
Old Jul 13, 2009 | 04:50 PM
yeah i plan on trying it tonight if there is still light by the time i get home
the fusible link that went on me was upfront buried next to the charcoal can and air filter once i swapped that out i got signal to the back relay on the drivers die firewall
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
