passinger side door will not open
Old Jul 28, 2009 | 07:41 PM
gordesky1's Avatar
ok yesterday the passenger side door wont open at all from the inside or outside...
cant get the side panel off either so we took off the top armrest and had a look inside and saw the outside door handle bar broke right off the handle...
and when we move the inside handle it moves the lock thing but does int open like it does int hit it hard anuff i even tried to stick a stick down there and push on it and it wont do anything...
so now how do i get this door open?
also sorry if i posted this in the wrong area but i didint know were else to put it at
Old Aug 4, 2009 | 07:31 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: passinger side door will not open
You should see a lever with a hole in it on the latch that the door handle rod fits into: press down on that(with the door unlocked) and it should open...
Old Aug 15, 2009 | 04:16 AM
gordesky1's Avatar
sorry it took long to get back
but i tried to push down on what you said and it still wont open that part seems really loose... makes a rattleing noise.
its either that is broken or the lock is stuck...
but still cant get the door open
1992 Trans Am
May 10, 2023 07:19 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
