emissions delete help
Old Nov 14, 2009 | 02:06 AM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
well i found out here in va they dont really check for emissions, so im gona remove it. its a 1984 camaro v6 2.8L backed with a t-5 5 speed. now my question is what do i have to do? i now i remove the smog pump and a lot of the vaccum things go away, but i need more details. will the computer tho a code? do i need to replace the carb? the disturber? all help is welcomed and thank you.
Old Nov 14, 2009 | 06:49 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: emissions delete help
Well smog pump would be a great thing to get rid of. I mean the rest can stay. now for the computer to throw a code possible. Not a clue though. Depends what you wanting. If you go carb then yes you will need new distributor ect.... but again not an expert on smog pumps anything electrical on the car I hate :P. So basically remove things that are not not needed. but IMO just leave it be. Unless your going to a bigger motor. Doesn't hurt having that stuff on there.
jaridjohn
Oct 5, 2015 07:01 AM
racereese
Oct 3, 2015 03:46 PM
djmarch
Oct 2, 2015 10:41 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
