need maf got it good then back stallin n heasitating again????
Old Nov 22, 2009 | 09:40 PM
Lestrey08's Avatar
Car: 84 camaro berlinetta
Engine: 2.8 V6
Transmission: 700 r4
ok so my 89 camaro 2.8 started stallin jerkin n what not ses light on run codes get 34 and 13 maf and o2 disconnects ecm under hood reads codes just 34 replaced maf codes gone but every now and again it wats 2 studder uses a lota gas runs rich and got codes 34,13,and32 i knw y i have 32 and its an easy fix but im trying get my car running rite again thx n advance just 4 reading
Old Nov 22, 2009 | 10:42 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
Re: need maf got it good then back stallin n heasitating again????
Code 13 is the o2 sensor circuit. You may have a poor connection in the wiring, a faulty circuit also from my book it could be a bad ECM although this is rare. If you are still getting a code 34 try checking your MAF wiring also could be linked to a bad ECM.
Old Nov 23, 2009 | 05:59 PM
Lestrey08's Avatar
Engine: 2.8 V6
thx checked o2 cleared codes now 32 showing every now and again
Old Nov 24, 2009 | 07:33 AM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
code 32 is your EGR system could be a faulty EGR valve or the vacuum line that goes to it could be cracked.
Old Nov 24, 2009 | 12:53 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
could also be a bad egr solenoid.
but it sounds like the egr could be sticking open and causing rough running issuses.
should be only open during cruse not idle or wot.
specialized
Jun 18, 2022 09:26 AM
86IROC112
Sep 7, 2015 01:37 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
