http://www.60degreev6forum.com
Car: 84 Firebird: F41, Pwr, Instr Pkg
Engine: LC1 (V6 2.8L, 280k mi)
Transmission: MD8 (700R4)
Axle/Gears: GU5 (3.23)
Factory Contradiction: 84 E2SE TPS Voltage .26 or .31 ???
This is in regards to a 1984 FBody VIN code '1' 2.8L V6 non-HO engine. Rochester E2SE Carb #17084632. This is an LC1 V6 107HP (it is NOT an LL1 125HP 2.8L V6). Partial vin is: 1G2AS8718ELxxxxxx
My 1984 Firebird Factory Service Manual (FSM) lists three(3) different TPS voltages! I've eliminated 0.255 volts as an option. But I can't find any clues about whether it's .26 volts per the adjustment text or .31 per the specification table - both from the same 6E section.
One
Section 6C3-30 "Carburetor Model E2SE" Lists:
VIN Code B 2.8L 0.255 V
VIN Code X 2.8L 0.310 V
VIN Code Z 2.8L 0.255 V
(=-0.1 volts)
None of these VIN codes appear to match my Firebird - so I've tentatively eliminated .255 from the list of options.
Two
Section 6E1-113 "Driveability and Emissions - Carbureted"
Subsection: Throttle Position Sensor - E2SE Adjustment
Step #5 lists "0.26 volts" "=-0.05 volts"
Three
Section 6E1-183 "Driveability and Emissions - Carbureted"
TPS Adjustment Specification Table:
2.8L: 0.31 +-.1 Volts
One
(=-0.1 volts)
Two
Three
