Flywheel ?
Flywheel ?
Im trying to figure out what flywheel i need to use to adapt a 91 3.1L to an 83 t5 with a cable clutch setup. Cant use my original one cause it isnt for an internally balanced engine. Not sure if a 91 flywheel will work with my clutch setup or not. any help is appriciated
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Flywheel ?
Get a wheel from a post-88. Whether the vehicle has a cable or hydraulic clutch or is FWD or RWD doesn't matter as long as the wheel doesn't have the balance weight on the engine side and has a 60* engine.
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Flywheel ?
They can, but it takes a lot of effort and you'll still want to make sure it's balanced at a machine shop. Probably better to get the right one the first time. Call around to some junkyards around you to see if you can find one.
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
