2.8-3800
Old May 28, 2010 | 12:03 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
2.8-3800
Ok I just picked up an 87 with a 2.8 and a friend has a 98 with the 3800 he is parting out ( salvaged from wreck). I know they are both 60* V-6's but can the long or short block be swapped for the other? also didnt see much info for the 3800 in the stickies and the ones for the 3x00 were a little confusing.
Old May 28, 2010 | 12:52 AM
Re: 2.8-3800
please all disreguard this post a different search revealed the 3800 is a90* block with 60* bellhousing pattern. sooooo obviously they can't mix
Old May 28, 2010 | 12:25 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
Re: 2.8-3800
You could most likely swap the 3800 in as long as you get the trans that came with it. The 3800 is a 90* and i believe the swap has been done plenty of times.
Old May 29, 2010 | 02:49 AM
Re: 2.8-3800
yeah just not sure if I want that much headache. Think I'll just find a good 3.4 and swap it instead.
Old May 29, 2010 | 08:13 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
Re: 2.8-3800
A 3.4 will drop right in and will bolt right up to your existing equipment.
