1992 Camaro Help
Car: 1992 Chevrolet Camaro
Engine: 3.1 V6, MFI
1992 Camaro Help
Hi my name is Nathan, I’m 17 years old, and I have a 1992 Camaro RS, V6 3.1 liter MFI
There been something wrong with it for a while now and do to the money we have been putting in to it my parents are about ready to sell it. So I could really need the help.
So here’s the problem.
It started about 3 weeks ago. When the car gets hot and I turn the car off It won’t start. Then once I seem to get it started it’s idles high RPMS, 2,000 – 2,500. And I now that not right because when I got the car it would idle at about 700 RPMS in park. Some other problems that I think that are related are: It chugs when I’m going slow through a neighborhood and the RPS jump around, Also when I pull in to my drive way it just dies, for now reason. When I drive it somewhere and then I turn off the car I won’t starts and I have to wait for the car to cool down.
And here is a list of all the thing that I have replaced:
Distributor Cap & Rotor
Ignition Module
EGR
Coolant Temperature Senor
Throttle Position Sensor
Idle Air Control Motor
Coil
Alternator
Water pump
So if someone could help me out so I can keep my car that would be great
Thank you
P.S. Spellings not the best so done comment on it. thanks
Ignition Module
EGR
Coil
Alternator
Water pump
Thank you
Car: 84 z28 h.o./ 92 rs
Engine: 305 h/o /3.1 v6
Transmission: hybird turbo 350/t5 bog warner
Axle/Gears: non posi 3.73 / ls 3.42
Re: 1992 Camaro Help
here some thing i had to check with my 3.1
timing
iac
clogged cat
fuel pump
injectors
injector wiring
injector o rings
sparkplugs
wires
hope it helps
i replaced most of the thing you did and it was my cat !
goodluck !
timing
iac
clogged cat
fuel pump
injectors
injector wiring
injector o rings
sparkplugs
wires
hope it helps
goodluck !
92camaroJoe
Aug 13, 2015 06:07 AM
