explain this part please.....
Transmission: 5-speed/T-5
Re: explain this part please.....
It's what the FPR uses to control uel pressure for different engine loads.
To be more technical, a vacuume referenced FPR keeps the delta fuel pressure the same over all engine loads.
Yes, you have to figure that the fuel pressure in the rail is not the effective pressure. It's simply the pressure relative to atmospheric. The issue is, that the engine only operates close to atmospheric at WOT. Anything but WOT and you have vacuum (actually pressure lower than atmospheric), this is the absolute pressure. Now, if you have a FP of say 43psi at the rail an the engine is operating at 10psi vacuum, or better a pressure of 10psi below atmospheric, the effective pressure would be 53 ps. Too much fuel delivery would result as the ECM relies on a constant fuel pressure. So, the vac referencing (which is similar/the same as boost referencing) keeps the EFFECTIVE fuel pressure the same throughout the intake pressure (vacuum) range
Car: 1986 Chevrolet Camaro
Engine: 2.8L V6 soon to be 3.4
Transmission: 700R4 soon to be WC t5
Wish I could give you rep points for an answer like that. Bravo.
Street Lethal
Apr 30, 2019 12:14 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
