fuel injectors
Old Nov 25, 2010 | 01:29 AM
jiyasa's Avatar
fuel injectors
What brand of fuel injectors would you guys recommend for a 3.1L?? Would Accel be okay and what pound flow would be considered stock? I'm looking to replace my other five, thanks in advance!
Old Nov 25, 2010 | 07:58 AM
southbay08's Avatar
Re: fuel injectors
we have the bosch injectors that would be fine for your application. You can give us a call or pm.
Old Nov 25, 2010 | 10:35 AM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: fuel injectors
the bosch seem to be the way to go..ive never really heard anything good about accel
southbay gives a pretty good deal to board members on bosch II's and bosch III's and they have a GREAT rep on here
Old Nov 25, 2010 | 10:39 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: fuel injectors
I've also read threads about using Ford injectors. You couls search. Also, depends on your budget. I got reman injectors from Rockauto for about $30 each and they work fine in my stock 3.1. May or may not last as long as new.
Old Nov 26, 2010 | 11:10 AM
southbay08's Avatar
Re: fuel injectors
We sell our reman's for $125 for the set. Just because an injector is not new
does not mean that it will not or should not last as long as new.
www.southbayfuelinjectors.com
516-492-6504
Old Nov 26, 2010 | 06:03 PM
jiyasa's Avatar
Re: fuel injectors
Okay, I'll look into it. Thanks guys!
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
