Need advice on which route to take
Old Jan 4, 2011 | 11:33 PM
baddaddio's Avatar
wanting to do a head swap in a 1992 3.1 MFPI with plans on a turbo set up. Currently I am having issues with a mystery stalling ghost. (see ECM thread) https://www.thirdgen.org/forums/dfi-...s-i-think.html
My question is this. Since I am planning a full head swap and possibly an ECM along with. Do I even worry about said mystery problem?? I Believe I can get a full top end for around 500.00.
My ride has 130k on it. Any thoughts gents??
Old Jan 5, 2011 | 11:59 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Re: Need advice on which route to take
Guess it just depends on if you need, or want, to drive it anytime soon.
Both times I had problems with stalling it was a bad fuel injectors(s). I would try to get that worked out before doing the swap. That way you know you're starting with something that runs, and if it doesnt run after the swap you'll be able to narrow down the possable problems. Also, I doubt your problem is caused by something you'll be replacing in the top end swap.
F-body-fan
Jan 12, 2023 01:49 PM
88CamZ
Oct 8, 2015 10:29 AM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
