Is this possible to do?
Old Sep 14, 2000 | 11:42 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
well..my column im my 2.8 camaro went out, and it brought the key cylinder with it so i cant start the car. its been sitting for like a month with no start...i wanted to know if its possible to bypass the key? if so how? if i stick in the key the cylinder turns but doesnt start. How can i start it? i just want to start it so its not a pain in the *** to start when i put in a new column. Thanks
89 RS
305 TPI...
Previous:
2.8 s/c'd firebird
Old Sep 15, 2000 | 12:02 AM
RenoLB8's Avatar
If I'm not mistaken, your cylinder has a little flat prong coming out of the bottom, and if you look in the column, it goes into a little slot. take out the cylinder, and you can start it with a flathead screwdriver. At least on my 88 bird you can.
-Reno
Old Sep 15, 2000 | 01:44 PM
Brian K's Avatar
Why not a push button... It would be different...
Old Sep 16, 2000 | 12:03 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
My car has a Chip in the Key i dono if yours is like it but mue wouldnt start when the chip oon the key went bad i hada sit 10 mins and wait for my security lock to go off and it SUCKED *** .. So make sure u ca do it...
