Performance Parts ?
Old Sep 21, 2000 | 10:05 PM
Vortex_89rs's Avatar
Performance Parts ?
Okay. I have heard people talking about getting fuel injectors that put out more fuel. This is all good, but I talked to my Power Mechanics teacher about this. If you increase the amount of fuel going into the chamber (from bigger injectors), wouldn't you need to increase the amount of air going into the chamber (via forced induction ie supercharger or turbo)? Otherwise your ratio would be off, and your car would run weird. Now, I don't know if the ECM controls how long the injectors are open or whatever, so the theory seems sound. More fuel means you need more air. Am I just missing something?
Vman
1989 Camaro RS
2.8 V6
K&N's
700R4 tranny
Cragar Street Pro rims (old Series 30)
Pioneer DEH-P3000
Old Sep 22, 2000 | 01:00 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, your man's right. That's why injectors are usually done after many other mods. The idea is that after the mods, the motor has more than enough air, but is getting choked by the stock injectors.
The ECM does control the injectors.. so if you put on high-flow ones, you wouldn't affect the car that much. Of course, the "extra" wouldn't get used, and you'd be wasting $$.
I thought I remembered reading once that our v6 injectors were the same as v8 injectors- but that might not be true. We could possibly go to v8 injectors from a junkyard instead of paying high $$ for new ones.
Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Sep 22, 2000 | 01:01 PM
82-T/A's Avatar
No, your totally right. Before you go get new injectors.. you should do other things first. For the injectors to benefit you, you will need more air flow. This can be accomplished by a writeup that I did in a message thats down below titled..
PORTING AND POLISHING RESULTS!!!!!
On this same forum.
You can also bore the throttle body to 57mm too.
A camshaft will increase flow too.
Todd
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
