Weird noise... Help please!
Old Nov 21, 2000 | 09:23 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
I have a pulsating squeak noise that gets louder and higher pitched as the throttle is increased.
I checked the belt....
The sound seems to be coming from around the Dist. or somewhere under the Plenum...
This is strange also, when under strong acceleration the noise dissappears. It is only when you slowly increase the throttle, or leave it at a moderate position that it makes noise.
Help me out! I have to drive a long way on wed! I dont want to be stuck on the side of the road like all the rustangs I've seen.
Thanks,
Daniel
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!! (New thing!)
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (17:24:14)
"No one knows until they learn" Leon Calrinsky (99)
Old Nov 21, 2000 | 11:43 AM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
set your bird in park, let engine run and spray some brakecleaner on those parts where the noise comes from, by using the throttle by hand till you hear the noise. it could also be an airflow inside a hose or tube-use a long screwdriver - put it on different engine areas with your ear on the handle, maybe you can locate where the noise comes from.
www.marion-becker-nidda.de
91 Firebird 3.1
Modsynomax ultra flow stainless steel
Old Nov 21, 2000 | 12:42 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
hm..is it a whistling sound when ur about 2.5k up, and if u rev it it whistles up and down with the throttle?
If so...check ur gaskets on the plenum and TB..the same thing happened to me and that was the cause.
Flowmaster 80 series, Random Technologies Cat, 3" intermediate pipe, SS Hand Made Tips, 3 1/4" out, Accel 8.8 wires, MSD Coil, MSD Ignition Module,MSD 6A Box
Currently Working On:
T5 swap
Next to buy:
Slp dual cold air intake!
F-body-fan
May 4, 2026 09:42 AM
db057
Jan 10, 2020 08:55 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
BWilcox
Sep 20, 2015 12:19 PM
