Distributor
Old Mar 4, 2011 | 08:18 PM
bkdbest's Avatar
Distributor
distributor question i have a 1985 305camero when im running down the road it is missing ive replaced the spark plugs spark plug wires rotor and distributor cap and ive set the timming now im wondering if it could be the distrubter itself or maybe the coil and can i replace the distrubter with the coil allready in the distrubtor or do i have to go back to distrubter with coil mounted on the same bracket as the egr relay the car is multi port fuel injected
sorry not much of a car machnic
Old Mar 4, 2011 | 09:03 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Distributor
Sounds like ignition module, located inside distributor under rotor. Parts stores can test them, but I never bothered since new part is like $35. Make sure to use the dielectric grease that it comes with per instructions. New distributors expensive, check on the igntion module and the pick up coil inside the distributor first.
BTW - this is the V6 section, your car is a V8 if it's a 305.
Old Mar 5, 2011 | 07:49 AM
bkdbest's Avatar
Re: Distributor
sorry about that its a 2.8 173 CI but thanks for the advice
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
