HELP GORILLA UNDER MY HOOD
Old Mar 7, 2011 | 12:54 PM
JJs84Berlinetta's Avatar
That's what it sounds like at least, this knocking noise in the morning i know the engine is tired 2.8 carb's 138k miles. Ok so i had low oil pressure so i changed the electric oil to mechinical guage was going to change the Engine coolant sensor over to mechanical also so disconnected the wire then realized i didn't have the right socket so replaced the wire now i have a high idle at around 1100 1200 rpms and this horrific knocking noise. know i look under the hood around the carb to see if i might have knocked something loose no vaccume hose disconnected oh wait what is this little wire here it is is coming from the driverside about mid engine has a litttle gray connector and is gray with a black strip anyone have a clue all i know is it is hot when the ignition is on but can't find anywhere for it to go
Old Apr 19, 2011 | 01:13 AM
ColAce1987's Avatar
Car: 1988 Firebird
Engine: 2.8 MPFI V6
Transmission: 700R4 Auto
Axle/Gears: 10 Bolt, 3.42 Std
Re: HELP GORILLA UNDER MY HOOD
I know about where it goes and what it is but I cant think of it right off. If Im not mistaken it does control the idle somehow. Have to check up on it a little. Either that or its a knock sensor connector.
Old Apr 19, 2011 | 12:45 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Check a little further up the wire as it may be discolored... Does it have a connector on the end or is it a broken wire?
No knock sensor on the 2.8, dude... Not in the F-body at least. 3.1 got it in 90...
Old Apr 20, 2011 | 12:12 AM
ColAce1987's Avatar
Car: 1988 Firebird
Engine: 2.8 MPFI V6
Wasn't for sure if they had one or not. I know I haven't seen one mine, but then again I never really looked for it either.
Old Apr 20, 2011 | 12:14 PM
Engine: 2.7L V6
Axle/Gears: 4.41
If it were there, it would be down by the starter in place of the coolant jacket plug .
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
