Aluminum Driveshaft
Aluminum Driveshaft
Is an aluminum driveshaft really worth it? What kind of performance or gas mileage improvements can I expect to see?
92 Bird 3.1L Auto
Best $750 I ever spent....
DRIVE IT LIKE YOU STOLE IT!
Kills:
93 Mustang LX (Before Mods)
98 or 99 Dodge Stratus (tough one, edged out at 40)
92 Camaro RS 305 TPI
Close Calls
94 Grand Am 3.1 V6
92 Cavalier 3.1 V6
01 Porsche 911 Turbo (Had em till first gear)
Mods-Jet Stage 2 Performance Chip, Accel Cap/Rotor, Accel 8.8 MM Wires, Accell Coil, AC Delco Rapidfire Plugs, Dynomax Catback, K&N
AIM name OVRCLCK350
92 Bird 3.1L Auto
Kills:
Close Calls
94 Grand Am 3.1 V6
92 Cavalier 3.1 V6
AIM name OVRCLCK350
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Fuel economy shouldn't be affected.. doesn't change how your engine runs or your gears so it's not a point there.. acceleration should improve as there's less rotational mass to spin up, and they're usually balanced alot better than the stock ones, thus far less driveshaft jitter at high speeds.. however they won't compensate for other drivetrain vibrations as well as stock from what I've read.
'86 Camaro SC, black /w silver racing stripes
2.8l MPFI/700r4
In search of new v8 engine & transmission
MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers
2.8l MPFI/700r4
Car: Death Mobile
Engine: 666 c.i.
I agree. The two biggest advantages of an aluminum driveshaft is less rotational mass, thus helping acceleration and higher critical speeds due to better balancing.
The total weight savings over a steel driveshaft is not a lot, though noticeable. If there is any fuel savings, it would be minimal.
If you want to get an aluminum driveshaft, scour the wrecking yards for a later model IROC, Z28, Formula or GTA with TPI engine, preferable a 305 5 speed or the L98. As an "acid test", put a magnet against it. If it is aluminum, it won't stick. The light grey color will also be a good clue as aluminum has a ligher color and does not rust.
