v6 Mods
Old Feb 7, 2001 | 05:37 PM
ReDRSMan's Avatar
v6 Mods
hello guys i want to make my v6 as fast as possible. i dont know what to do. its stock and i hate it. could you guys tell me what i cant and should do to make it fast as hell.
Old Feb 7, 2001 | 07:14 PM
87 Firebird's Avatar
K&N Filter, A Compcam, 1.5mm roller rockers, headers, higher stall convertor, shift kit, a n aftermarket exhaust, MSD Ignition box, Juice, A Turbo/Super charger, P&P the heads, increased compression rings + pistons, if it's a 2.8 change it to a 3.1, do the free mods, and that's about it. Or you could just get yourself a 3.4 and swap it in...
Kevin-87 Firebird 2.8 liter A4
!Cat, !Maf, !Air Intake, K&N, Bosch Platinum +4, Blue Streak Cap & Rotor
Performance Rebuild in the planning stages...
Best 0-60 10.26 seconds...for now
Old Feb 8, 2001 | 12:04 AM
RenoLB8's Avatar
Hmm, exhaustive AND expensive list. Bang for the buck, first get a full tune up. Plugs, wires, cap and rotor, change ALL fluids, and upgrade wherever possible. (Switch to 8mm wires while you're trading them, go for Delco Rapidfire or Splitfire plugs, Accel or MSD cap and rotor, etc.) Cost? Maybe $50-75.
While you're changing your tranny fluid, hop it up to B&M trickshift fluid, and if you're a little ambitious, put in a B&M shift kit while you're down there. Cost? About $45-50.
Now, modify your airbox to make sure you're getting good flow. Free.
160* thermostat and fan switch, only $10 and some playing around, even better.
Now, for speed mods, The best for under $100 is underdrive pulleys. About $50-75. Then, Dynomax exhaust, about $150-250 installed. By then, you'll be feeling it and loving it.
Under the hood, get some 1.6 ratio roller rockers, and learn a little about your valvetrain putting them in. About $200 there, but I'm close to guessing.
Good luck, and welcome to the boards!
-Reno
Old Feb 8, 2001 | 02:54 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
I forget Brian's site address; but check out http://3gv6.org/ he has a V6 tip section.
"5 out of 4 people have a problem with fractions"
My Camaro: http://home.earthlink.net/~singleton052095
Old Feb 8, 2001 | 06:23 PM
SlowCamaro88SC's Avatar
don't forget good tires....
Old Feb 8, 2001 | 09:33 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Brian's site:
http:www.geocities.com/overlift
86 Sport Coupe, 2.8 V6, dead stock, but not for long!
"Little girls play with ponies!"
www.geocities.com/camman86
Rock fans click the secret link on my site!
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
