accel fuel injectors
Old Feb 23, 2001 | 11:16 PM
bub's Avatar
bub
summit racing has a whole set for 173.69
2.8 15lbs per hr and 3.4 17lbs perhr i orderd
3.4 for my 2.8 they said ill have to get costom chip burned my question is will it start with different injectors i had it rebuilt and bored 0.30overcrane cam all the stuff i dont have the cash for a costom chip right know and need to get it back from the garage but i could always use the stock ones to get home any advice the fuel injectors arent that hard to take out so changing them isnt that bad
we are told that talent creates its own opportunities.yet, it sometimes seems that intense desire creates not only its own opportunities,but its own talents as well.
Old Feb 24, 2001 | 03:12 AM
RenoLB8's Avatar
Summit are really good guys. They will never intentionally try to screw you. In this case though, they're wrong or didn't understand you. If you're just dropping the 3.4 injectors in, then you'll be fine, no fancy chip stuff needed.
-Reno
'88 Firebird LB8
"Cerberus"
http://www.angelfire.com/il/Firebird28/index.html
Old Feb 24, 2001 | 03:47 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Actually the summit guys are probably correct. If you put in larger injectors, they're probably going to pass more fuel per pulse, thus screwing up your ECM's mixture controls (ECM doesn't know how much fuel it dumps in the engine, it just knows the pulse width it sends to the injector). Your ECM might be able to compensate from O2 sensor input, but it's gonna run rich when it starts in open loop, and I'm not sure just how much compensating it can do. When you start modifying things like your injectors, it could be in your interest to invest in prom burning equipment or find a friend who has the equipment. With the larger injectors you'll want to hop up your fuel pressure a bit and modify the prom's injector pulse tables.. Glenn91L98GTA has a much better understanding of this concept and can explain far better than I can.
'86 Camaro SC, black /w silver racing stripes
2.8l MPFI/700r4 /w special 2nd gear delete option
In search of new v8 engine & transmission, now contemplating t5 swap to get me out of this mess.
MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
