Fuel pump test?
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Fuel pump test?
I'm replacing my fuel filter and, because I've got engine issues that may be fuel related, I thought it may be a good time to test the fuel pump. Before connecting the output side of the filter back up I thought I could attach a hose to it and place the end in a suitable container and activate the fuel pump. Maybe using the terminal on the aldl connector. If I do this how much flow (volume in a given time) should I get out of the filter?
92camaroJoe
Aug 13, 2015 06:07 AM
