What happens if my EGR valve aint hooked up?
Old Apr 9, 2001 | 07:07 PM
RS'er's Avatar
Is it bad? We have no emissions inspections in florida so I dont care if it makes my car pollute (oh poor ecosystem ya like I feel bad for you).
Will it affect how my car runs?
Old Apr 9, 2001 | 08:06 PM
KED85's Avatar
Unless you COMPLETELY BLOCK OFF both parts, you'll run into some extra heat, where you engine bay may not appreciate it.
Incidentally, it will NOT affect your perfomance if it's hooked up.
It enhances the engine exhaust by making it flow thru the system better.
PLUS, I DO LIKE BREATHING, FINALLY, CLEAN AIR IN CA, AFTER WAITING ABOUT 20 YEARS!
Make the EGR system work right, it only helps ya, not hurt ya.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Apr 9, 2001 | 08:20 PM
RS'er's Avatar
<font face="Verdana, Arial" size="2">Originally posted by KED85:
</font>
I enjoy breathing every once in a while too. Whats an extra arm or two growing out of your stomache from emittions?
Old Apr 9, 2001 | 08:23 PM
KED85's Avatar
Chat Soon,
KED85
Karl
Old Apr 10, 2001 | 09:49 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The computer supposedly will lean out the fuel mixture when EGR should turn on. This is because when the exhaust gas re-enters the engine, it richens the exhaust. The computer leans out the air/fuel mixture to compensate. So; there might be some pinging if you unhook the valve.
And that EGR (like Karl said) will only kick on when the car's in a high-speed, low-rpm condition- as in, you're just cruising down the freeway, and don't need any horsepower.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 10, 2001 | 11:14 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
go to www.sethirdgen.org and go to the tech section it has a 2 page article on the EGR valve and says what will happen if u dont use it with a computercontroled car
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
rjcme
Sep 5, 2015 01:23 PM
