Thermostat Housing
Old May 4, 2001 | 01:15 AM
Ovrclck350's Avatar
Thermostat Housing
What size are the bolts? Sorry, it's 1AM and I'm wanting to get up in a good mood and not be hunting for sockets.
Yes, I still haven't changed it. I keep trying, and giving up.
Old May 4, 2001 | 06:26 AM
HotRod's Avatar
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
I just changed my stat to a cooler one last night. The bolts are 1/2" or whatever the metric equivelent is. The passenger side is easy, just get in there with a socket. The drivers side I got a wrench on there and a used a hammer with a socket extension to knock the bolt loose. Then I used two different 1/2" wrenches to get the bolt out (alternating the teeth on the wrench, that is why I used two). Good luck, it can be done, might be easier to remove the TB.
86 Camaro 2.8, 92 Firebird 3.1, 1951 Chev 327, Four-wheeling hybrid.
Old May 4, 2001 | 09:03 AM
KED85's Avatar
Oh, how I could be funny.....
I recall everything was 13mm.
It can be done, without removing everything in sight.
I did it the lazy way.
Watch out putting it back in, it is aluminum, strips easy!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
