Need AC
Car: 1986 Firebird
Engine: 2.8 V6
Is there anything left of the system? There should be a huge box against the passenger side of the firewall with a vertical opening; that's where the evaporator went. A silver can would be in front of it (accumulator). There'd be a hard steel line on the passenger side's main frame rail, with a two-wire connector going to it; that's the "high pressure" switch. There'd also be the condensor, which is a radiator-looking thing in front of the radiator. (It's what most of us see when we look at our radiators above the air dam... we don't see the radiator, we see the condensor.)
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
nope all there is left is a bunch of conectors that go noware, a lot of spliced wires and a **** load of electrical tape.other than the t-stat controls being messed up, it looks like there is no ac system
-NightWolf
-NightWolf
Let's make it simple.
What does the HVAC panel say?
Does it have a position for Air Conditioning on it?
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Chat Soon,
KED85
Karl
Car: 1986 Firebird
Engine: 2.8 V6
What's the heater box on the passenger side firewall look like? If there's no spot for the vertically-mounted rectangular condensor, then you'll have to change the box out...
