rear end question
Old May 21, 2001 | 10:34 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
rear end question
Ok a friend of mine is junking a 87 IROC. He says it has a stock 3.73 posi rear. But looking on this site, it looks like a stock posi rear would be a 3.23 correct me if I'm wrong). So my question is would it be worth it to swap my stock 3.42 non-posi rear for the 3.23 posi?
One more question...it is possible someone swapped in a 3.73 on his car...is there a way to tell by looking at the gearbox if its a 3.23 or a 3.73?
If anyone's wondering, my near future mods:
K&N drop-in filters w/ baffles removed
Catco cat converter
Dynomax 2.5" cat-back
MSD GM Blaster coil
MSD 8mm Heli-core wires
MSD 6A ignition
Got all this stuff, just gotta install it.
[This message has been edited by Mikes86SC (edited May 21, 2001).]
Old May 21, 2001 | 11:22 AM
SUPER-SPORT-CHEVY's Avatar
If it is a 2:73 posi I want it!
But anyway for performance reasons it would not be worth swaping rears from 3:42 to 2:73. There is a tag on limited slip rearends that states the gear ratio. If the tag is gone just pull the cover and get the numbers.
SSC
Old May 21, 2001 | 12:47 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
As far as I know, the 3.73/posi axle stopped in '85. When I was out hunting for the 3.73 axle, I was looking for only a couple years- 82-85. '84 Camaro H.O's got the 3.73/open/drum axle.. found a couple of those cars, but not the axle. I found my 3.73/posi/disc axle on an '84 trans am (engine code "G" for "I hit Gold!"), and they also came on the '84 Z28's.
So I think you're right... stock would be a 3.23. As for someone switching gears, that's a great possibility (I hope it's true for ya!), but there's no way to tell unless you drop the rear cover (as SSC said). I'd say it's worth smelling that stinky gear lube for it... a 3.73 posi would be great for ya! My axle, with the GM gears, had the ratio stamped on the ring gear (41:11). I counted the pinion teeth (11) and ring teeth (41) anyway... so if the gears in the back aren't stamped, just count teeth & divide.
Put a clothespin on your nose when you drop the cover... yuck.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
