getting more hp out of my v6
Old May 31, 2011 | 01:36 AM
needanswers's Avatar
Car: 1983 Camaro
Engine: 2.8L V6
Hi so i recently have been trying to fix up my 1983 camaro 5 speed manual with a 2.8L V6 engine id like to try and avoid an engine swap so i was wondering how i could give it alot more hp without swaping in a different engine. Thanks.
Old May 31, 2011 | 03:29 AM
Firebird1990's Avatar
Car: 1987 Trans Am,1989 GTA
Engine: 5.0 Tuned Port Injection, 5.7 tpi
Transmission: 700r4, 700r4
Axle/Gears: 2:73 Posi, 3:27 Borg Warner 9 Bolt
Re: getting more hp out of my v6
turbo or hybrid, absorb as much information in the v6 section as possible everything you ever wanted to know is there.
Old May 31, 2011 | 06:42 AM
project89's Avatar
its a waste of time u have a carbed engine, the bottom end is weak in the early carbed engines.
if u want a lil more power out of it do the basics
tune up
headers
cat back ex system
if u want to get slightly more involved get a cam and a set of heads off a fuel injected 2.8/3.1 or 3.4
aluminum heads will require a swap to fuel injection along with a piston swap and a ton of other things u need to do which would be a total waste on a carbed motor shortblock
Old May 31, 2011 | 09:35 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
If you wan to make over, lets say 160hp, you're gonna want to swap with a 3.1 or 3.4. Both of them are east swaps and will net you a decent increase in power. Not to mention a stronger and more modifiable engine.
