The quest for the most beautiful 3.1 continues...
Car: 1991 Z28
Engine: 5.7 TPI
Just added these pieces- what do you think?
If you check the attachment for the cable bracket at the front of the plenum, you will see an extra spacer, so as to move the bracket forward to keep it aligned correctly with the TB after the spacer was fitted.
