Wiring fan switch
Old Jul 11, 2001 | 02:37 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
Wiring fan switch
anyone care to tell me how to wire the fan to a remote switch?
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
Old Jul 11, 2001 | 04:31 PM
Brian K's Avatar
email syxxgunnar@aol.com He has just finished his and worked out all the quirks...
Old Jul 11, 2001 | 05:00 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
I wired mine from the wire going directly into the back of the fan. A wire from your battery to a switch, then from the switch to the back of the fan. Easy.
Old Jul 12, 2001 | 11:34 AM
Kevin S's Avatar
Here ya go Graeme!
Needed....1 toggle switch,a wire splicing connector and wire.
On my 2.8 it has a fan switch on the passenger head near the firewall.It will have 1 wire connected.This is a ground wire for the relay.
Splice "your" wire to this fan switch wire.Run the new wire inside to where you will mount your toggle.Connect "your" wire to the toggle.Connect a shorter piece of wire to the toggle and ground the other end.
What this will do is let your fan run as it would normaly with the toggle switched off.When you want the fan on just switch the toggle on,it will kick the relay on, thus turning your fan on.
I did mine this way because I don't need the fan running all the time.When I'm in town I switch my toggle on.When I'm at the track I switch it on.When I'm driving on the highway at 55 I turn it off.If the temp gets high enough to turn the fan on it will as it normaly would.
Kevin S
89 RS w/2.9
modded some but not heavily
SIMPLE SIMON met a Pieman Going to the fair, Said Simple Simon to the Pieman "What have you got there?" Said the Pieman unto Simon "Pies, you ********!"
Old Jul 17, 2001 | 10:47 AM
Kevin S's Avatar
TTT,I hope you got this Graeme.
www.geocities.com/kevinwv1
The next time you think your perfect,try walking on water!
[This message has been edited by Kevin S (edited July 17, 2001).]
Old Jul 17, 2001 | 12:05 PM
Actually...i havent... i cant locate that wire....can u give me better location on it?
1989 Firebird
Coming for my v6:
#3 Forever
Old Jul 17, 2001 | 02:02 PM
Kevin S's Avatar
Mine is one the passenger head.On the corner closest to the firewall.The sensor is screwed into the head with 1 wire connected to it.That wire is a ground.Use a toggle switch to ground that wire and your in business.Besure you don't cut it,just splice into it.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
