Squeaking!!!! Please help me fix it!
Old Aug 8, 2001 | 04:43 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Ok, I'm pretty sure the squeaking has to do with the tension of the belt. But from what I've been told, you can't tighten the belt. Because I have a belt tension thing ( I don't know what it's called, it's the thing you twist to loosen the belt) And that thing should have enough tension so the belt doesn't slip. And at first when I start the car it doesn't squeak but when it warms up it starts to squeak, and sometimes afterward it stops, and comes back and it really annoys me. This is really bad especially when I have women in the car! Do I need a new belt tension thing? I'm pretty sure it's not the belt because I have checked it and there aren't any missing teeth and it all looks really good. Should I take it to a mechanic and have him fix it?
1992 RS 3.1L Bone Stock
"Yeah, it's a V6 SO WHAT!?"
Old Aug 8, 2001 | 05:27 PM
Blade3001's Avatar
Try that spray can belt dressing stuff but I'm willing to bet you need a new belt anyhow. It could be still streched even though it looks ok.
'83 MPFI 2.9L V6 Dark Metallic Blue Firebird
Don't ask, just accept it
Old Aug 8, 2001 | 09:59 PM
Jiffy's Avatar
Mine is doing the same thing, I was just about to make my own topic.
Jeff
92 Camaro V6, mods: K&N, modified air box, JET chip 2,Dynomax Cat & Cat Back Systemwww.camarors.4t.com
Old Aug 8, 2001 | 11:07 PM
85maro's Avatar
Mine is doing the same thing, and i tried the belt dressing and it worked for like two min. .Then it just wore off. And my belt isn't bad because just replaced it when the guy put the new motor in.
Tim
Old Aug 9, 2001 | 01:00 AM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
So you think I need a new belt? Man that sucks. If any of you other guys that have the squeaking problems find a solution please post and tell me! Thanks!
Old Aug 9, 2001 | 01:41 AM
Jiffy's Avatar
Just out of curiosity, how many miles do you have on your car, since we have the same year,elevario?
Jeff
Old Aug 9, 2001 | 01:42 AM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
I just passed 106,000. How about you?
Bubbajones_ya
Oct 25, 2015 08:01 PM
Giocio
Oct 1, 2015 12:20 PM
dusterbd
Sep 29, 2015 08:40 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
