want to swap fuel injection to carberator on 1986 camaro
Old Sep 19, 2011 | 11:15 PM
xplore's Avatar
I was wondering if any one knows if i can pull a intake off a older 2.8 v6 and put in on my 1986 camaro 2.8 v6 engine so that i can go with a carb instead of using the fuel injection. The engine and transmission out of a 1986 camaro are going to be put in a 1971 buick skylark and i pulled all the wireing harness under the hood and then got in the car and realized theres way to many wires and ill have to remove the dash to get to them and pull the gas tank out to stay with the fuel injection. So im hopeing some knows how i can put a carb on this motor.
Old Sep 19, 2011 | 11:49 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: want to swap fuel injection to carberator on 1986 camaro
the carb and intake from a 84 and earlier camaro/firebird should bolt right up, idk about the older FWD ones
Old Sep 20, 2011 | 12:42 PM
ex-x-fire's Avatar
The 82-84 v6 carbs are computer controlled.
FWD v6 intakes are different.
82 S-10 might have a non comp. contolled carb. They do have a vacuum advance distributor (which you'll need).
Edelbrock make a 2piece intake, a base & a stock carb top or 4bbl. carb top.
That 2.8l is going into an intermediate car? It's gonna be very underpowered for that application.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
