4th Gen V6 Tranny
Old Dec 1, 2001 | 11:29 AM
86Chicken's Avatar
4th Gen V6 Tranny
Will a 4th gen V6 5-speed easily fit in a 3rd Gen Bird?
My tranny bit the big one and I might be able to get my hands on one from a 3.4L 4th gen and I was wondering if this would be a direct swap.
Dale
1986 FireBird V6
Old Dec 2, 2001 | 01:41 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Maybe the transmission and drivetrain board might know more about this, it seems no one here has done it. I would think it would bolt up, but isn't there a servo in the 3.4 transmission, that could cause some problems.....
Old Dec 2, 2001 | 04:34 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
the case pattern where it meets the bell is supposed to be FORD! unlike the 3rd gens where it used a canted standard gm you will need the bellhousing as well but the clocking of the hydralics may not be similar
Old Dec 2, 2001 | 10:05 PM
Camaro_hunter_d's Avatar
If its a manual swap on both. meaning 5 out for another 5, it will go. the bellhousing is the same. Its still a 60* motor housing. Auto may be trickier. Talk about servos and what not. If its just the converter lock up that is the problem easily over come by making a manual lock up switch.
Old Dec 3, 2001 | 08:47 AM
86Chicken's Avatar
This will be a 5 to 5 swap. Actually I was going to swap in a low mile 3.4 at the same time to eliminate a bad engine vibration I have.
I forgot about the hydraulics. Does anyone know if they are the same?
So far this is starting to sound like it might not be a very good idea. Oh well
Thanks so far
Dale
sweet_87_iroc
Sep 25, 2015 10:01 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
Thornburg
Aug 25, 2015 01:46 AM
Zachattack0925
Aug 12, 2015 09:52 PM
