adjusting air and fuel intake
Car: Pontiac FIREBIRD
Engine: 3.8L
3.1 running bad after new fuel pump. my hunch is that now that i have good fuel pressure to much is being fed. and throwing it off iv heard it takes a computer to fix this issue. O -Meter of some sort? or is there another legit way? someone told me to run it for 30 days. =/ any suggestions?
thanks thirdgen
thanks thirdgen
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: adjusting air and fuel intake
Not likely, chances are you have a seperate issue, though if you want to try resetting the ECU, simply disconnect the battery for a bit (10-30m)
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Aug 17, 2015 02:00 PM
