Help :O
Old Dec 1, 2011 | 05:37 PM
emerald91fbird's Avatar
Car: 1991 firebird
Engine: 3.1 l v6 mpi
Transmission: auto
Help :O
okay so i have a 91 firebird it takes a bit to start it but when u let off the gas an come to a stop it wants to stall any ideas on what i should do to eliminate this or what it could be Thanks in advanced
Old Dec 2, 2011 | 10:30 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Help :O
First check the Idle Air Control valve is working and the air passages are clean. Then.....
Old Dec 2, 2011 | 10:39 AM
Car: 1991 firebird
Transmission: auto
Re: Help :O
clean both about three days ago and just put the air box back in after painting it but this problem was their be4 i painted it i have new plugs and wires new coil oil change my cat is being replaced next week tho... soo i dont know im gonna try to do some of the grounds today
Old Dec 2, 2011 | 01:47 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: Help :O
Then you'll just need to work your way through all the usual stuff. Grounds, sensors, egr stuck open, fuel pressure etc. etc. All the way to the injectors.
Old Dec 2, 2011 | 06:47 PM
Car: 1991 firebird
Transmission: auto
Re: Help :O
ok when i hit the brakes the car dips the revs higher can u give me around about idea of all the ground
