MPFI Parts Help
Car: 1982 Firebird
Engine: 2.8 N/A
Transmission: Manual 4 Speed
MPFI Parts Help
Hey guys, i recently picked up an MPFI intake for my firebird and need some help gathering the remaining parts ill need to install it. Aside from whats in the pic i also have the ECM and harness. Besides what will transfer over and connect from my carb setup what hoses, fittings, etc. will i need to get everything installed. Im not a car guru and this is more work than ive done in a while. lol Thanks Also, if these pics show up huge ill fix it ASAP, sometimes that happens even if i resize them.
Transmission: 5-speed/T-5
Re: MPFI Parts Help
Grab a wire diagram for the ECM/engine, and make sure you have all of the corresponding sensors.
When it comes to swaps, even using factory parts, there will be some "custom" parts needed, especially for the hoses and tubes, unless you order ALL of the tubes and hoses and parts they attach to as well.
Just look at schematics that show where things connect, and make your's connect to the same parts.
Re: MPFI Parts Help
dont forgte about a fuel pump the mpfi will not run off the carb fuel pump, actually it will prolly idle really bad and thats about all
Car: 1982 Firebird
Engine: 2.8 N/A
Re: MPFI Parts Help
Does anyone know a place online that i can get the schematics? Also, what fuel pump would be recommended for this swap? Thanks
LT1Formula
20
Nov 14, 2015 12:02 AM
Thomas
Oct 3, 2015 05:34 PM
