Can someone tell me what this is?
Old Feb 19, 2012 | 12:31 PM
kylerzoncs's Avatar
someone told me that this was an egr valve, but when ever i look it up, it always looks a whole lot different from mine. any help?
Attached Thumbnails Can someone tell me what this is?-2012-02-19_13-25   Can someone tell me what this is?-2012-02-19_13-25   Can someone tell me what this is?-2012-02-19_13-25
Old Feb 19, 2012 | 12:40 PM
Joecat's Avatar
Engine: 2.8L V6
Transmission: 7004r
Re: Can someone tell me what this is?
where did you find it?
Old Feb 19, 2012 | 12:57 PM
kylerzoncs's Avatar
the pic says it all
Attached Thumbnails Can someone tell me what this is?-2012-02-19_13-53
Old Feb 19, 2012 | 01:08 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
It is an EGR valve.
Old Feb 19, 2012 | 01:14 PM
kylerzoncs's Avatar
well a lot people have videos on how to clean egr valves, is there a way to clean this type? im guessing its an electronic egr valve.
Old Feb 19, 2012 | 01:16 PM
kylerzoncs's Avatar
and also, people say a vacuum hose is supposed to be connected to it, there is no port hole/connecter place for a vacuum hose to go.
Old Feb 19, 2012 | 02:40 PM
wyochimneysweep's Avatar
Car: 92 chevy 1/2 4 wheel drive
Engine: 5.0L with TPI
does it got a electrical connection?
Old Feb 19, 2012 | 02:44 PM
kylerzoncs's Avatar
yes, it has a electrical connection, so im guessing it doesnt have a vacuum hose that goes to it? and how do i clean the egr valve since its electrical?
Old Feb 19, 2012 | 04:54 PM
That one is what is called a "digital" EGR valve. It has 3 pintles of different sizes that control the amount of exhaust gasses that are passed through. There is no vacuum signal to this type if EGR valve.
Old Feb 19, 2012 | 06:07 PM
kylerzoncs's Avatar
ooh, okay, thank you. now the vacuum lines in it are all messed up and cut and fallin apart, can you tell me what type of lines i would need to use to repair them?
Old Feb 19, 2012 | 10:27 PM
beleneagle's Avatar
You can buy the hard plastic vacuum lines at most part places. Auto Zone carries them by the pcv area. The rubber lines are behind the parts conter.
