Mechanical Guages
Old Apr 2, 2012 | 10:40 AM
ricklee4570's Avatar
Mechanical Guages
Where is the recommended place to run the plumbing lines for installing mechanical oil and temperature guages on a 92 3.1l engine?
I know the electrical guage for oil is by the oil filter--is this the best place to plumb in the mechanical temp guage?
Where is the water temp reading taken at?
Old Apr 2, 2012 | 01:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: Mechanical Guages
Water temp would replace your factory idiot light switch in the front outer corner of the driver's side head (behind the a/c bracket). Depending on the gauge you have you might need an adapter. I had to use one (temperature probe was much smaller than the hole in the head), but the salesperson at Summit Racing knew exactly which one I needed. Give them a call, phone # at www.summitracing.com .
For oil pressure you've got a combo-switch in that 92 3.1; it runs the fuel pump AND provides the oil pressure light. All you need is to install a t-fitting. That way the original switch still works and you can plumb in the mechanical oil pressure gauge too.
Old Apr 5, 2012 | 11:24 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
There is a pressure tap right above the combo unit (2.8s have another oil pressure unit here for the fuel pump), or you could just get an electric gauge and the proper gauge sender. The pressure tap plug has a 1/4" square drive hole in it, use a standard 1/4" ratchet and extension without a socket on the end to remove.
But don't most 92s have the full gauge cluster? Do you think your factory gauges are inaccurate?
Old Apr 5, 2012 | 11:30 AM
I don't trust the factory electronic gushed. For oil pressure I prefer mechanical guages.
sheachopper
Jul 31, 2019 11:27 AM
sjorgens
Oct 1, 2015 07:54 PM
