V6 to V8 fuel pump
Old May 15, 2012 | 09:39 PM
samuelromph's Avatar
V6 to V8 fuel pump
hi i have a 1989 v6 2.8l fuel injected firebird my v6 fuel pump went out and i had to put a v8 camaro fuel pump in it will the v8 fuel pump give my car more speed or hp?
Old May 15, 2012 | 09:41 PM
Re: Pontiac V8 Swaps
hi can anyone answer my question? i have a 1989 v6 2.8l fuel injected firebird the fuel pump went out and i put a v8 camaro fuel pump will it give me more hp or speed?
Old May 24, 2012 | 01:54 PM
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Transmission: 700 R4
The injectors will only flow what they are rated at. Any excess fuel will be returned to the tank.
Old May 24, 2012 | 03:10 PM
project89's Avatar
the v6 and v8 pumps are identical as far as i know.
the only pump that would be different is the tbi pump whihc only has a presure of 15 psi
Old May 24, 2012 | 03:51 PM
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Re: V6 to V8 fuel pump
And usually the V8 pumps are cheaper than the V6 ones. Whats up with that?
Old May 24, 2012 | 04:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The regulator determines the pressure, not the pump.
Old May 24, 2012 | 06:08 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Old May 24, 2012 | 07:31 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
They both use the same pump, it flows around 190 LPH.
Pretty much all the MPFI/TPI cars from the 80's/90's use the same pump aside from the Sy/Ty, TTA/GN, L67's and other boosted factory cars.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
