another gremlin
Old Aug 3, 2012 | 05:22 PM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
another gremlin
Checked all vac lines, spark plugs, wires, sensors, replaced icn and all vac lines along with brake booster.
Problem is, it drives a little hot all the time. But when I come to a stop sign or light, the car stumbles and dies sometimes. I'm at a loss as to what to check next.
Old Aug 3, 2012 | 08:45 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: another gremlin
whats a Icn??? The Idle Air Control? IAC?
How hot does she run?? Check t stat or just replace it, they are very cheep. 180* one. Check coolent level, make sure none is exscaping/leaking out. And also make sure your fan is working properly. A overly hot car will run rough depending on the temp and what your ecm is programed to do when its hot... I.E. reduce timing, IAC position..exc
Any codes??
Reset the ecm and start over if all the coolent areas check out.
Just my 2 cents.
Old Aug 5, 2012 | 07:51 AM
Re: another gremlin
Yeah I mean iac, typing kinda fast.
Yeah the coolant is full and fan is working fine. Have a 160° thermostat in. So possibly the water pump which I really don't feel like changing. lol
Old Aug 5, 2012 | 08:26 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Re: another gremlin
Looks like you answered you own question on the problem or where to look at/ Water pump is no fun I can attest to that...lol
Old Aug 5, 2012 | 09:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: another gremlin
If the stock injectors are still in the engine I'd replace them. You are also better off with the stock 195* F thermostat.
As for running hot, air dam in place? Remove the upper radiator support and look down between the radiator and the A/C condenser. That area likes to fill with debris.
Check the distributor base timing, should be at 10* BTDC on a warm engine with the EST/BYPASS connector open.
If you've had the battery disconnected need to do an idle learn procedure. Otherwise the engine will surge, stall, and sputter at low speeds and idle.
RBob.
Old Aug 5, 2012 | 05:43 PM
Re: another gremlin
Damnit,
I forgot About the idle relearn thing. * smacks myself upside the head.*
I replaced the battery and didn't even remember it.
The 195° is better than a 160° or 180°? I was always under the impression that a cooler engine is a happier engine.
Water pumps on a 3.1 is a royal PITA. On my other 91 back in 2000 I broke 3 bolts getting the old one out. My girl at the time almost broke up with me cause we were supposed to have dinner with her parents. ( I loved that car for that :-) )
Old Aug 5, 2012 | 08:29 PM
Re: another gremlin
Idle relearn and 3rd new radiator cap and it's fixed.
Thanks guys
P.S. never trust aftermarket radiator caps from Autozone. lol Napa had an oem one that works perfect!
85f-bird
Jul 10, 2006 08:51 PM
thunderstick
Dec 11, 2005 07:14 PM
BanditWS6
Nov 3, 2003 06:03 PM
rx7speed
Theoretical and Street Racing
Jan 26, 2002 06:45 PM
Adams87Camaro
Jul 7, 2001 08:43 PM
