Coolant fan !
Coolant fan !
My coolant fan starts at around 220 degrees F on my Camaro 91 3.1L
How can I make it start either at lower temperature or even from the start ?
Do I need to change the thermostat sensor or something else ?
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
Re: Coolant fan !
Replace the coolant temp sender with one with a lower temp setting... or you can buy adjustable senders so you can set it at whatever you want.
Car: check
Engine: check
Transmission: check
Re: Coolant fan !
RBob.
Re: Coolant fan !
My A/C has not been working for more than 12 years
What is (burn a PROM with it lowered) ? and how to do it ?
Wouldn't it work if I just change the temperature sensor to a lower degree ?
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Coolant fan !
You can't change the CTS to a lower degree... It doesn't work that way. The ECM is in direct control of the fan relay whether or not the car has A/C and/or it works. You can add a wire and second relay and knock out a plug in the passenger's side cylinder head (by the lifting eye) to turn the fan on at a lower temp, or add a switch that passes through the radiator for the same effect. Unless you want to modify the stock ECM calibration (same thing as RBob said above).
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Coolant fan !
yank the AC rad out, it will drasticly change your cooling for the better. [after 12 years its empty, but just go slow when you crack the lines lose]
the fan will barley need to run, long as your air dam is good.
Re: Coolant fan !
By calibrating you mean to say get a "computer" and change the settings. How much does the computer cost ?
Can I connect wires from the fan connection w/ a switch and run the fan continously with it ? In rush hours it seems a bit lame to use a switch to turn on the fan everytime the temp rises
What do you guys prefer ? Does anyone of you have done this ?
